CMS108 Laser Scanner
ROMER Inc. announced the launch of CMS108, a high-precision, non-contact laser scanner available for their portable coordinate measuring machines.
ROMER Inc. announced the launch of CMS108, a high-precision, non-contact laser scanner available for their portable coordinate measuring machines. The CMS108 is the adaptable and adept at scanning a wide range of materials with enhanced sensitivity to color and surface finishes. Its improved accuracy makes it attractive for inspection and reverse engineering applications where laser scanners have been unable to meet tight tolerances. The CMS108 mounts with a kinematic joint to the seven-axis ROMER portable CMMs, which include the Absolute Arm SE and the Infinite 2.0 SC Arm.
The CMS108 is the most precise laser scanner offered by ROMER with an accuracy of 20µm, which is a 16 percent gain in accuracy over previous scanning solutions. In addition, the device was engineered for applications with a wide variety of color and surface finishes. Flying dot technology allows the laser scanner to rapidly detect changes in color and surfaces via their reflectivity. An operator can scan traditionally difficult finishes, including shiny and mirrored surfaces, without making manual exposure adjustments. The laser scanner can transition from matte to shiny features without additional calibration. With 3 different line widths and differing point densities, the CMS108 is able to perform inspection routines on small intricate parts and large surfaces.
