Compact Vertical Machining Centers
The small footprint make the compact vertical machine centers an economical option for small shops that require a second machine or an additional spindle. Each machining center is manufactured and tested to assure it meets the highest quality and accuracy standards. In addition, it is recognized for improved accuracy and repeating due to the solid rigid construction.
Palmgren's line of compact Vertical Machining Centers are ideal for production lines, short runs, one-offs and prototyping. The machining centers are an excellent solution for machining small parts. The small footprint makes it an economical option for small shops that require a second machine or an additional spindle. Each machining center is manufactured and tested to assure it meets the highest quality and accuracy standards. In addition, it is recognized for improved accuracy and repeating due to the solid rigid construction. Each Palmgren Machining Center features a 10-tool magazine with an automatic tool changer and a user-friendly portable handwheel. In addition to the 10-inch x 31-inch model, Palmgren's line of Machining Centers include 7-inch x 24.5-inch and 8.5-inch x 27-inch models.
