Cylindrical Vibration Isolation Mounts
J.W. Winco Inc. offers inch sized GN 451.1/GN 451.2/GN 451.3 cylindrical-type vibration isolation mounts with stainless steel components.
November 1, 2014
These RoHS-compliant vibration isolation mounts, also known as vibration mounts, anti-vibration mounts, vibration bobbins or rubber bumpers, are suitable for the elastic mounting of machine units such as motors, compressors and pumps. These mounts are simple and economical construction elements. Their resilience and their broad range of different sizes and dimensions allow them to be used in many applications that require vibration isolation.
GN 451.1 type has two threaded studs, GN 451.2 has one tapped hole and one threaded stud, and GN 451.3 has two tapped holes. Isolation mount body is made of natural rubber (NR), vulcanized, 55 durometer (shore hardness +/-5 degrees). Cover plate is stainless steel and tapped inserts/threaded studs are made of stainless steel, molded"
