Lucifer Furnaces Inc. shipped two dual-chamber atmosphere muffle ovens to a customer for the purpose of heat treating superconducting wire used in medical, pharmaceutical and industrial applications.
The superconducting wire will be processed inside the muffle under a positive flow of protective nitrogen atmosphere. Each furnace has two 12"x12"x18" chambers capable of temperatures to 760° C with a uniformity of +/-5° C. Unique door-mounted fans circulate the heated atmosphere inside the work chamber, providing uniform temperature throughout.
A Honeywell cascade programmer coupled with an SCR power supply provides precise temperature control inside the muffle around the workload. The furnace is designed with lightweight insulating firebrick, a silicon-carbide hearth plate and heavy-gauge coil-wound heating elements located on both sides as well as under the muffle.
A double-pivot horizontal swing door with alloy cladding and a high-temperature gasket seals against the muffle to minimize heat loss while providing easy access to the work chamber and safety for the operator.
- payload ( workload)
payload ( workload)
Maximum load that the robot can handle safely.
