ELP Electric Linear Module
The SCHUNK ELP can be adjusted in two simple steps, making it a very user-friendly electric linear module. The end positions can be mechanically adjusted with a screw, and the speed of extension and retraction is adjusted using rotary switches on the side of the unit.
May 16, 2018
Speed can be automatically adjusted, depending on extension weight and no shock absorber adjustment is necessary, because the drive automatically regulates the brake process. The ELP is practically wear-free with a long service life and low maintenance cycles. The control and power electronics are directly integrated into the module, and can be controlled by a fieldbus distributor or through digital signals.
