EN 239.4 Plastic Hinges
J.W. Winco Inc. announced it offers EN 239.4 plastic hinges with an integrated switch, in metric sizes.
August 1, 2014
These RoHS-compliant hinges were designed for monitoring guard doors and covers of machines and production equipment. Opening the door activates the switch contacts, which then interrupts a protective circuit via a break contact (NC) and at the same time signal the door opening by closing a make-contact element (NO). The integrated design, which features an ultrasonically welded enclosure, makes these hinges compact, tamper-proof and easy to mount. J.W. Winco also offers matching EN 239.3 hinges without safety switch.
Hinges are matte black glass fiber reinforced plastic, with hinge pins of stainless steel, European Standard No. 1.4305 (American Standard Series 303). Versions with switch on the right or switch on the left are available. Four types are offered: connector plug on top, connector plug on back, cable connection on top and cable connection on back. Cable lengths of 2 or 5 meters are available.
