FE060-25-EM Servo Drive
The FE060-25-EM is the first servo drive of the new FlexPro digital drive family from ADVANCED Motion Controls (AMC). Designed with compact form and power density in mind, the micro-sized FE060-25-EM can outperform larger-sized digital servo drives and still be integrated into tight spaces.
May 20, 2019
At just 1.5 x 1 x 0.6 inches (38 x 25 x 16 mm) in size, the footprint of the drive is approximately the same as two standard postage stamps. In other words, four of these drives can fit on a standard business card. Even with its small size, the FE060-25-EM can supply brushed, brushless, stepper, and linear servo motors with up to 25 amps continuous current and 50 amps peak current.
Features include:
  • 1.5 x 1 x 0.6 inches (38 x 25 x 16 mm) in size
  • 10-55 VDC supply voltage
  • 25A continuous current
  • 50A peak current
  • Highest power density servo drive from ADVANCED Motion Controls to date
  • EtherCAT Communication
  • Incremental encoder and BISS C-mode feedback
  • Torque, velocity, and position operating modes
  • Configuration and full loop tuning
  • IMPACT architecture
A developer version is available for proof-of-concept and testing purposes - part number FD060-25-EM. It comes with an FE060-25-EM soldered to a larger board that is equipped with various connectors for simplified interfacing.
The small size of the FE060-25-EM makes it suitable for cobots (collaborative robots), AGVs, portable devices, lab and warehouse automation, military equipment, and any other integrated design.
