![](/sites/default/files/styles/product_image/public/product_images/0515-GardnerMicrometer.jpg?itok=20Jx368Y)
The Fowler Xtra-Value II Electronic Micrometer from Paul N. Gardner Co. has a choice of measuring range, an LCD with an inch/metric switchable resolution, and is designed for general purpose measuring. A switchable resolution of 0.00005" and 0.001mm, and an accuracy of 0.00016"/0.004mm provide precise readings and accurate measurements.
Carbide measuring faces provide long life and wear resistance. A ratchet thimble applies consistent force for repeatability between users. A jet back and grey enamel finish provide durability and wear resistance.
Features:
• Jet black and grey enamel finish
• Large LCD display
• Resolution of .00005"/.001mm
• Accuracy of ±.00016"/.004mm
• Direct RS 232 output
• Carbide measuring faces
• Absolute and incremental modes
• Ratchet thimble
• Includes case
- micrometer
micrometer
- wear resistance
wear resistance
