GN 115.10 Latches
GN 115.10 Latches
J.W. Winco Inc. offers GN 115.10 latches with gripping tray, lockable, in metric sizes. These RoHS-compliant latches with gripping tray are used in applications that require a molded recess in addition to the latching mechanism, e.g. if operating elements are not allowed to protrude for reasons of space.
April 29, 2016
J.W. Winco Inc. offers GN 115.10 latches with gripping tray, lockable, in metric sizes. These RoHS-compliant latches with gripping tray are used in applications that require a molded recess in addition to the latching mechanism, e.g. if operating elements are not allowed to protrude for reasons of space. A rotary movement (limited to 90°) of the three-edged wedge moves the latch behind the frame, with the run-up bevels at the latch making it easier to close the door.
The front frame is zinc die-cast with either black plastic coated textured finish or silver textured finish. The tray is plastic, either gray or light gray. Latch housing is zinc die-cast, black plastic coated finish or chrome plated finish. Latch hardware is zinc-plated, blue passivated steel. Five types are offered: with triangular spindle, square spindle A/F 7 mm, square spindle A/F 8 mm, slot, or double bit. Twenty-two different latch arms cover the latch distance in a range from 4 to 50 mm.
