GN 417 Zinc Die-Cast Indexing Plunger Latch Mechanisms
J.W. Winco, Inc. offers GN 417 metric zinc die-cast indexing plunger latch mechanisms with rest position. The RoHS compliant indexing plunger latch mechanisms are used for applications where the plunger has to stay in its retracted position.
October 25, 2016
J.W. Winco, Inc. offers GN 417 metric zinc die-cast indexing plunger latch mechanisms with rest position. The RoHS compliant indexing plunger latch mechanisms are used for applications where the plunger has to stay in its retracted position. To achieve this, the knob is rotated by 90 degrees after being retracted, as a notch keeps the plunger in this position.
The design of the holes/slots allows for fixed or adjustable mounting of the latch mechanism base onto Tubing or T-slot aluminum structures. A receptacle for the indexing plunger latch pin with adjustable slots in the base is also available upon request.
The plunger housing is zinc die-cast, with a black plastic coated textured finish, while the plunger pin and spring are stainless steel. The pull knob is constructed from a matte black glass fiber reinforced nylon plastic, which is not removable.
