LED Ring Illuminator
A low-cost LED ring illuminator from Titan Tool Supply Inc. features a constant-current design to provide powerful, microscope-quality light output with no color shift when dimming.
September 13, 2012
A low-cost LED ring illuminator from Titan Tool Supply Inc. features a constant-current design to provide powerful, microscope-quality light output with no color shift when dimming. A typical incandescent bulb has a life of 200 hours; the new Titan Tool Model T-30 LED illuminator has a life of approximately 10,000 hours. Priced at $265.00, the T-30 features 40 high-bright LED lights set in a CAD-design, precision-aligned array and includes an integrated controller to adjust brightness from 10 percent to 100 percent.
A universal power source connector with a built-in transformer enables worldwide operation from 100-240VAC, 50-60Hz, Titan Tool states.
Additional features include:
360 degree, shadow-free illumination
3-point, soft-tipped, secure mount to fit lenses from 1.25" to 2.6" (32mm to 66mm) in diameter 6500 degree K spectrum (approx.)
Silent, no-vibration operation
Measures 1.09" thick x 4.08" O.D. x 5.3" long (28mm x 104mm x 135mm) with optimal working distances from 3" to 6" (76mm to 152mm)
Machined aluminum and molded plastic closure for rugged durability
