Lightning Cool
Lightning Cool
Tanis Technologies has what you need to be able to put an end to replacing spindle drive belts, drawbar components, rubber motor mounts, through-spindle coolant seals and more with its Lightning Cool system.
April 1, 2010
Tanis Technologies has what you need to be able to put an end to replacing spindle drive belts, drawbar components, rubber motor mounts, through-spindle coolant seals and more with its Lightning Cool system. This system fixes several problems related to the Fadal drawbar system and it adapts a Deublin rotary coolant union to the factory Fadal spindle and provides reliable through-spindle coolant that will not leak coolant onto your belts and other critical components like the factory system does, according to the company. Fadal engineers credited the Lightning Cool system for fixing seven out of the nine most common problems with Fadal machines, which is why they made this system a factory option in 2008.
