Loc-N-Load Plates and Workholders
Phillips Precision Inc. rounds out its Inspection Arsenal quick-swap fixturing to include a system for all common inspection equipment. Create a lean, standardized process across all inspection equipment with Loc-N-Load plates and workholders from Inspection Arsenal.
March 20, 2017
Phillips Precision Inc. rounds out its Inspection Arsenal quick-swap fixturing to include a system for all common inspection equipment. Create a lean, standardized process across all inspection equipment with Loc-N-Load plates and workholders from Inspection Arsenal. Lean practitioners testify that the design reduces the most expensive waste affecting profits – defective parts, excess motion, over production, and waiting … waiting for talented people and expensive spindles.
Install a simple docking rail designed for CMMs, vision system, optical comparator or gage arm. Standard size interlocking Loc-N-Load plates can then be quickly and easily moved between machines as needed.
By fixturing on quick-swap plates, operators can change parts in and out without building and breaking down setups. Several unique parts can be setup or multiples of the same part fixtured and programs repeated. Plates can be dedicated and kept with the job box for fast, repeatable setups and are in-stock and ready for same-day shipping. Plates are sold individually or available in preconfigured bundled systems (plates and workholders) for CMMs, gage arms, vision systems and optical comparators.
  • vision system
