![LSM-6902H Laser Scan Micrometer has Ultraprecise Scanning Motor LSM-6902H Laser Scan Micrometer](/sites/default/files/styles/product_image/public/product_images/LSM-6902H2.jpg?itok=BYJ7Y6go)
Mitutoyo America Corp. announces the release of the LSM-6902H Laser Scan Micrometer to its sensor systems product line. The LSM-6902H Laser Scan Micrometer noncontact, high-accuracy measurement system is an excellent option for measuring pin gages or plug gages.
The ultraprecise scanning motor in the LSM-6902H enables the highest measurement accuracy down to 0.3µm with excellent Gage R&R performance since measurements are noncontact. The standard output is RS-232C with analog I/O with an optional 2 channel Digimatic code output unit available.
LSM-6902H Features:
- Thanks to excellent linearity, an accuracy of ±0.5μm over the entire measuring range and a higher accuracy of ± (0.3+0.1ΔD) µm over a narrow range are guaranteed
- The best repeatability available in the 25mm/1" class
- Resolution: 0.01 to 10µm (selectable) (0.000001 – 0.0005in)
- Scanning rate: 1600 scans/s
- Laser scanning speed: 112m/s
- micrometer
micrometer
