MAC motor With Built-in Controller
JVL's newest additions to its portfolio is a complete, high-capacity MAC motor with rating of 3,000W. MAC motors are complete servo systems including a high-dynamic AC servo motor, hall-sensors, encoder, power supply, driver and positioning controller and Nano-PLC, as well as facilities for incorporating various control modules such as Bluetooth, WLAN, ZigBee, EtherCAT, EtherNet/IP, CANopen, DeviceNet, Profibus, Profinet, Nano PLC, RS232/RS485/USB and Process Control.
October 29, 2018
The MAC motor sets completely new standards for the performance and size of servo controls. With a length of only 311.8mm for a 3000W motor with a torque of 9.55/28.6Nm at 3000rpm, this MAC motor matches the size of traditional servo motors without built-in controllers with flange 130x130mm. This has only been possible through the use of extremely compact motors and the development of electronics and mechanics that utilise the latest technologies and manufacturing methods. So what about vibrations and temperature? As with the other integrated servo motors in the range (50W to 3,000W), both the motor and all electronic components have been specifically selected to withstand the rigorous demands required by industrial use.
Powering this motor is easy since it only requires connection of the main voltage of 3x400VAC through the M23 connectors. Control voltage for the encoder and microprocessor circuitry is 24VDC: In an emergency-stop situation, where an approved relay has cut-off the main power, encoder position and other values are maintained by this control voltage. In some applications, however, this is not needed and in those cases an optional internal 24VDC supply can be used, requiring only an AC main connection. Furthermore, highly effective switching technology is used to ensure low heat generation resulting in appreciable energy savings.
One of the big advantages of using the integrated MAC motors is that you don't need to install a separate servo driver or controller in a control cabinet. This gives you many subsequent advantages: Space savings in your control cabinet, saving of expensive motor and encoder cables, saving time (and money) for cabling, noise is minimized due to internal cabling and also installation errors between driver and motor are eliminated. In addition, service is much easier, since the motor and controller can be replaced as a single integrated unit. Hence downtime is minimized and production is maximized.
  • process control
    Method of monitoring a process. Relates to electronic hardware and instrumentation used in automated process control. See in-process gaging, inspection; SPC, statistical process co…
