Model 42-M36 Forced-Air Recirculating Oven
Lucifer Furnaces supplied a forced-air recirculating oven to a manufacturer of medical and aerospace parts. Model 42-M36 will be used to heat treat 17-4 stainless steel.
October 9, 2018
With a chamber size of 12"H x 18"W x 36"L, powered with 13KW, the oven heats quickly with side-mounted element holders housing coiled, low watt density resistance wire. Standard features include heavy-gauge sheet steel construction, 4 ½" multilayer insulation, a 16-gauge stainless steel liner and a horizontal swing door with safety switch.
A rear-mounted, high-volume fan directs air past heating elements then throughout work chamber for uniform heating. This convection-style oven is equipped with a programmable controller and two-pen chart recorder.
