PB Series Portable Bench Scale
A portable, battery-powered, NTEP-approved bench scale with a removable display for easy viewing when setting up for high-volume UPS box shipping applications is available from Alliance Scale Inc. The Alliance/CAS PB series portable bench scale is lightweight and has a carrying handle with a display that is removable for easy viewing and can be supplied with an optional wall-mount bracket.
June 22, 2016
A portable, battery-powered, NTEP-approved bench scale with a removable display for easy viewing when setting up for high-volume UPS box shipping applications is available from Alliance Scale Inc. The Alliance/CAS PB series portable bench scale is lightweight and has a carrying handle with a display that is removable for easy viewing and can be supplied with an optional wall-mount bracket. Powered by alkaline or rechargeable batteries, users can create a shipping department anywhere and connect to networked devices and receipt printers with an RS232C port.
Legal-for-trade and weighing only 14.5 lbs., the Alliance/CAS PB series portable bench scale is available in 150-, 300-, and 500-lb. capacity models with 1/3000 external resolution. The detachable indicator has a large 6-digit LCD display and this scale is suitable for a range of applications, including assembly and in-plant or field service weighing.
The Alliance/CAS PB series portable bench scale is priced from $310.00.
