Featuring universal multiple vices, the PolyClamp Verso from CERATIZIT is ideal for use in 3-, 4- or 5-axis machines, where it easily clamps all part variants. The system’s jaws are slimmed down for this purpose while allowing even more jaws to be clamped per base rail for clamping larger unmachined or finished parts.
A scale lasered onto the centric vice is a further benefit when it comes to handling. It allows the jaws to be positioned evenly and precisely on the rail, in accordance with requirements.
The PolyClamp Verso is equipped with a quick jaw change system as standard. Using just two screws, the fixed and adjustable jaws are released, removed upwards or repositioned. This significantly reduces setup times because each jaw is individually removable without having to dismantle the others.
