Quick-Change, Roll-On, Turn-On Ceramic C-Prime Discs
Weldcote offers its new lines of Quick-Change, Roll-On and Turn-On ceramic C-Prime discs for steel, stainless steel, ferrous and nonferrous metals.
Used for finishing, grinding, deburring and blending applications, Weldcote's high-quality Quick-Change, Roll-On, ceramic C-Prime discs are manufactured of an improved ceramic grain structure that is available in seven grits ranging from 24 to 120 in its 2-inch size disc and six grits ranging from 24 to 120 in its 3-inch size disc. Its Quick-Change, Turn-On, ceramic C-Prime discs are available in six grits ranging from 36 to 120 in its 2-inch size disc and three grits ranging from 36 to 80 in its 3-inch size disc.
Using an improved manufacturing technology, Weldcote has developed a proprietary ceramic abrasive grain with a finer crystallized structure that offers longer life, more aggressive grains and improved self-sharpening features when compared to traditional ceramic products. The ceramic grain improvements provide high metal-removal rates at fast cutting speeds with low grinding temperatures and low friction.
"Our new Quick-Change ceramic discs provide users with longer life and a higher rate of material removal," said Joe O'Mera, CEO of Weldcote. "The coated discs, which can be quickly and conveniently changed out, are constructed entirely in the U.S. with a proprietary new material that provides more aggressive performance."
The new Weldcote Quick-Change, Coated, Roll-On and Turn-On ceramic discs eliminate the need for installation tools due to their twist-on-and-off attaching systems, which allows for rapid disc change and maximizes productivity by minimizing downtime.
The line is entirely made in the U.S., from design and lamination, to its die-cut and spin-weld processes.
