![Radial Arm Drill Presses Radial Arm Drill Presses Feature Extended Reach and Tilting Drill Heads](/sites/default/files/styles/product_image/public/product_images/Radial%20Arm%20Drill%20Presses%20from%20Palmgren.jpg?itok=setpJr6V)
The Radial Arm Drill Presses from Palmgren are designed with an extended reach and tilting drill heads that are ideal for large or odd-shaped work pieces. In addition, the head of the drill press moves 12 ½ inches forward or backward. The table tilts 45 degrees left and right and swivels 360 degrees around the column for easy machining of holes at any angle. The drill presses are made from durable cast iron with spindles supported by high quality ball bearings.
The #9680342 Radial Drill Press from Palmgren is the ideal choice for odd-shaped work pieces. The presses come with Palmgren’s three-year warranty.
- drilling machine ( drill press)
Machine designed to rotate end-cutting tools. Can also be used for reaming, tapping, countersinking, counterboring, spotfacing and boring.
- radial drill
radial drill
Large drill with an arm that pivots about a column to provide positioning flexibility and great reach and stability. See drilling machine, drill press.
