![Full Line of Shaft Collars, Mounting Collars and Sleeve Couplings Shaft Collars, Mounting Collars and Sleeve Couplings](/sites/default/files/styles/product_image/public/product_images/Stafford%20Accu-Clamp%20Shaft%20Collars.jpg?itok=bdcQL_Z-)
A full line of shaft collars, mounting collars and sleeve couplings that provide highly accurate working surfaces and mar-free clamping has been introduced by Stafford Manufacturing Corp.
Stafford Accu-Clamp shaft collars feature an integral clamp on one side while leaving the other flat and perpendicular within 0.001” TIR to permit mounting next to precision bearings, sprockets, and gears. For mounting components, Accu-Mount and Accu-Flange collars have a centering hub with predrilled and tapped holes on their flat side and flange, respectively.
Providing strong, mar-free clamping power, Stafford Accu-Clamp shaft collars are available made from aluminum, steel and stainless steel in 0.5” to 2” ID sizes. A precision one-piece sleeve coupling with a rigid center clamp section and the Accu-Clamp feature at each end is offered for a distortion-free coupling with a more precise fit and shaft-to shaft concentricity within 0.001” TIR.
- centering
centering
1. Process of locating the center of a workpiece to be mounted on centers. 2. Process of mounting the workpiece concentric to the machine spindle. See centers.
- flat ( screw flat)
flat ( screw flat)
- inner diameter ( ID)
- total indicator runout ( TIR)
Combined variations of all dimensions of a workpiece, measured with an indicator, determined by rotating the part 360°.
