Slim MT Inserts and Toolholders
Featuring multiple straight flutes designed for machining longer threads in small to large diameters, Carmex Precision Tools Slim MT inserts and toolholders deliver high productivity for a lower price. Constructed of an advanced carbide and coating combination for extended tool life, most of the inserts are double sided. The toolholders are
nickel-coated for high wear resistance and feature a unique clamping mechanism.
Jim White, national sales manager for Carmex USA, said, “The new Slim MT line was developed to offer customers a quality tool for generating longer threads in an economic package. The longer inserts not only make deep-hole threading easier but deliver an excellent finish with less cycle time. Slim MT holders and inserts are available in a wide variety of sizes and multiple international configurations.”
  • flutes
    flutes
  • threading
    threading
  • wear resistance
    wear resistance
