The Vargus Mach TM is a high-performance thread milling tool engineered to enhance machining productivity and efficiency. Designed with advanced features, it is ideal for demanding applications requiring precise threading and superior surface finish.
Key Advantages:
High Feed Rate: Allows for more material removal per flute.
Reduced Machining Time: Significantly shortens cycle times.
Extended Tool Life: Enhanced durability for prolonged use.
Excellent Surface Finish: Ensures superior finish quality.
Features:
Improved Cutting Edge & Reinforced Geometry: For handling high loads.
Coolant Thru Design: Enhances chip flow and surface finish.
Large Core Diameter: Increases stability.
Additional Flutes: Enables higher feed rates.
Advanced Surface Treatment: Strengthens cutting edges and improves finish.
Optimal Flute Length: Provides higher rigidity and efficient chip evacuation.
For more details, visit the Vargus Mach TM page.
- coolant
- feed
- threading
threading
