SP1560 Gage
SP1560 Gage
The TQC Surface Profile and Coating Thickness Gage from Paul N. Gardner Co. Inc. is a combination gage that can be equipped with two different tips, one for surface roughness and another for coating thickness.
The TQC Surface Profile and Coating Thickness Gage from Paul N. Gardner Co. Inc. is a combination gage that can be equipped with two different tips, one for surface roughness and another for coating thickness. Comes complete with two tips and a glass calibration plate, all in a leather pouch.
Technical Specifications:
Range: 0-3.4mm / 0-0.13 inch
Resolution: 1micron / 0.04 mil
Accuracy: +/-5micron / 0.2 mil
Thread: M2.5 x 0.45
Stem Diameter: 8mm / 0.3 inch
Maintenance:
This instrument is precision-machined. Never drop it or knock it over.
Always clean the instrument after use. Clean the instrument using a soft dry cloth. Never clean the instrument by any mechanical means such as a wire brush or abrasive paper. This may cause permanent damage, just like the use of aggressive cleaning agents can. Do not use compressed air to clean the instrument.
Always keep the instrument in its case when not in use.
Annual calibration recommende.
