Standard-Duty Detent Pints
Jergens Inc. has introduced a line of Standard Duty Detent Pins that further expands the company's growing line of Quick-Release Detent Pins for a multitude of holding and removal applications.
Jergens new Standard Duty Detent Pins provide fast, easy, alignment for use in a wide range of operating environments, from general machining and industrial uses, to service in heavy duty work truck applications.
A new line of economical General Purpose Lanyards will also be made available to compliment the Standard Duty Detent Pins.
Design and performance features of Jergens new Standard Duty Detent Pins include:
Body (shank) is CRES 303 stainless steel with CRES 316 stainless steel spring and detent ball Pins are activated by either a push or pull motion Includes a stainless steel split ring for attaching optional
General Purpose Lanyard Available in all popular grip lengths and pin diameters from 3/16" (4.765mm) to 1" (25.4mm)
Optional materials, grip lengths and pin diameters are available
General Purpose Lanyards feature:
Standard loop with tab in lengths of 6" (152.4mm) or 12" (304.8mm)
300 Series stainless steel cable, 1⁄16" (1.59mm), with clear nylon jacket, 1⁄8" (3.18mm)
Other cable diameters and special configuration styles are available by special order
