Stark Zero Point Mounting System
Fixturing set up time is reduced by as much as 90 percent with the new Stark Zero Point Mounting System from Carr Lane Roemheld Manufacturing Co.
Fixturing set up time is reduced by as much as 90 percent with the new Stark Zero Point Mounting System from Carr Lane Roemheld Manufacturing Co. This comprehensive system utilizes clamping components and insertion nipples, which provide an immediate zero point orientation, allowing faster and more accurate fixture set up and changes.
Existing fixtures can be easily adapted to the system, which allows for highly accurate positioning and repeatability, fast payback, an extension of the fixture's life, and increased productivity. Several variations are available, from single parts to complex systems.
