TRITAN 365 Series Lamps
Spectroline TRITAN 365 series are multi-LED, broad-beam UV-A (365 nm) lamps for a range of NDT applications. Each lamp features three ultra-hi-flux UV-A LEDs for NDT inspection, plus a white light LED to illuminate dark work areas.
Spectroline TRITAN 365 series are multi-LED, broad-beam UV-A (365 nm) lamps for a range of NDT applications. Each lamp features three ultra-hi-flux UV-A LEDs for NDT inspection, plus a white light LED to illuminate dark work areas. A rubber bumper with a Borofloat glass lens protects the LEDs from damage. The lamps are compact and lightweight – only 16 ounces (454 g). Their rugged lamp bodies have an ergonomic design that provides hours of safe, fatigue-free use.
TRITAN 365 Series lamps are available in three versions to meet specific NDT inspection requirements.
- The TRI-365HB high-intensity model provides a nominal steady-state UV-A intensity of 9,000 µW/cm² at 15 inches (38 cm).
- The TRI-365DB and TRI-365DBB are standard-intensity models that are "tuned" to ensure a maximum steady-state UV-A intensity of less than 5,000 µW/cm² at 15 inches (38 cm), to address aerospace concerns.
- The "DBB" lamp has a faceplate with integral black light filters that cover the LEDs and reduce the output of wavelengths longer than 400 nm.
A certificate of compliance for both output and wavelength measurements is supplied with each lamp, and all units meet ASTM UV-A intensity and wavelength specifications for FPI and MPI.
