TubeTastic! oil skimmer
Abanaki Corp.'s TubeTastic! oil skimmer is for use on machining centers with little or no access to the coolant sump from above.
Abanaki Corp.'s TubeTastic! oil skimmer is for use on machining centers with little or no access to the coolant sump from above. The company's line includes disc, belt and tube skimmers; coolant mints; aerators; coolant mixers; and removal equipment. According to the company, the low-maintenance and reliable products extend coolant life, eliminate odors and improve tool wear.
