DMG/Mori Seiki USA's X-Class machine has a thick, high-rigidity bed with X- and Z-axis linear guides in a high position, and a spindle with large-diameter bearing. The machine has a heat-symmetrical structure that disperses heat evenly, and coolant circulation inside the casting to minimize thermal displacement. Available in a variety of models, it uses LED lighting and a hydraulic unit equipped with an accumulator.
- coolant
