XR3 6-axis Drive Rack
The XR3 6-axis drive rack with field replaceable, front-mounted, 3U plug-in amplifiers support both linear and PWM topologies. The XR3 can control any combination of brushless, DC brush or stepper motors at up to 320 VDC operating voltage and 30 A peak current capability. Both the current loop and servo-loop are digitally closed to ensure the highest level of positioning accuracy and rate stability. This processing capability allows the XR3 to provide loop closure rates up to 20 kHz and to handle both digital and analog I/O processing, data collection, process control and encoder multiplication tasks in real time.
November 1, 2018
Standard features include per-axis brake control logic, auxiliary encoder feedback, analog I/O expansion, 16 opto-isolated inputs, 16 opto-isolated outputs, up to 12 high-speed differential outputs, three PSO (Position Synchronized Output) external sync inputs, 3 TTL or isolated PSO outputs, one opto-isolated data-acquisition input and two STO (Safe Torque Off) sense inputs. The XR3 supports open-loop control, standard square-wave encoder feedback, analog input feedback control and absolute encoder feedback.
Options for the XR3 include three different levels of integrated encoder multiplication including options that support dual-loop encoder feedback, drive-rack cooling, rack or slide-type mounting and multiple-axis Position Synchronized Output (PSO) I/O for low-latency, position-based process control.
The XR3 contains two configurable power supply sections to support a variety of motors with different operating voltages. When only one motor voltage is required, the power supply sections are joined together for even higher power capability.
  • process control
    Method of monitoring a process. Relates to electronic hardware and instrumentation used in automated process control. See in-process gaging, inspection; SPC, statistical process co…
