![Z-Carb HPR High-Performance Roughing End Mills 900 Tools Added to Z-Carb HPR Line With Long, Extended Reach, and Chip Breaker Options](/sites/default/files/styles/product_image/public/product_images/Z-Carb-HPR_Display.jpg?itok=Z2mpa_ps)
To meet customer demands, KYOCERA SGS Precision Tools has expanded the popular Z-Carb HPR high- performance five-flute end mill line with over 900 new tools featuring new long, extended reach, and chip breaker options to combat a wider variety of high metal removal roughing operations.
Utilized extensively in the aerospace, automotive, and general machining industries, SGS’s high performance Z-Carb HPR five-flute roughing end mills are perfect for achieving high material removal rates (MRR) and superior finishes. The specialized five-flute design is engineered to drastically increase productivity 20-40% over conventional three and four-flute end mills. It features variable indexing geometry, which improves chatter suppression over symmetrical designs. The Z-Carb HPR portfolio is equipped with various lengths, reach, square, and corner radius styles, along with new chip breaker options to address different machining situations. These end mills are coated with Ti-NAMITE®-M and Ti-NAMITE®- A, ensuring superior performance even in difficult-to-machine materials like Titanium and Stainless Steel.
Features & Benefits:
NEW long, reach, and chip breaker options available!
Over 1,700 items in portfolio
Full complement of corner radii available
Central coolant hole and chip breaker options available on select diameters
Plain and Weldon Flat options available for diameters 1⁄2” / 12mm and above
(other retention methods available upon request)
1/8" and 6mm cutting diameters and above
Special tooling design attributes available upon request
Ti-NAMITE®-M coating for higher heat resistance to enhance tool life in Cast
Iron, Steel and with difficult to machine materials like Titanium.
Ti-NAMITE®-A coating for superior wear, edge build-up resistance and
extended tool life in high temperature alloys and stainless steel applications.
Series Product Details:
Cutting Diameter: 1/8" - 1" / 6,0mm - 25,0mm
Length of Cut: 1/4" - 3" / 9,0mm - 75,0mm
Overall Length: 1 1/2" - 7" / 54,0mm - 170,0mm
Shank Diameter: 1/8" - 1" / 6,0mm - 25,0mm
Corner Radius: 0.010" - 0.250" / 0,3mm - 5,0mm
Coatings: Ti-NAMITE®-M, Ti-NAMITE®-A
Special Options: Internal Coolant, Weldon Flat, Chip Breaker
Material Applications:
Steel ≤ 45 HRc
Stainless Steel ≤ 45HRc
Cast Iron ≤ 45HRc
High-Temp Alloys
Titanium Alloys ≤ 45 HRc
Industry Applications:
Aerospace
Medical
Power Generation
Automotive
Mold & Die
Casting & Foundries
General Engineering
- alloys
alloys
- chatter
chatter
- coolant
- die casting
die casting
Casting process wherein molten metal is forced under high pressure into the cavity of a metal mold.
- flat ( screw flat)
flat ( screw flat)
- milling machine ( mill)
- shank
shank
