Multi-Master Milling Heads
January 25, 2024
Multi-Master Milling Heads With 1.5xD Long Flutes
Following long experience with MULTI-MASTER milling heads, ISCAR is expanding their application range by increasing the depth of cut vs. tool diameter ratio from the current 0.7xD to 1.5xD.
The new milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability.
The new milling heads are available in .312-1.00” diameter range.
MM EC-CF-Z7/9-1.5xD Interchangeable 7-9 flute solid carbide endmill heads with 1.5xD flute lengths, different helix, variable pitch and various corner radii.
MM EC-CF-Z4-1.5xD Interchangeable solid carbide heads with variable pitch and 1.5xD flute lengths for chatter free roughing and finishing operations. High material removal rates.
MM ERS-1.5xD Interchangeable solid carbide rough milling heads with 1.5xD flute lengths, for high metal removal application.
It is recommended to use the new long flute milling heads with MM S-A (straight shanks) reinforced, Weldon type or SURELOCK shanks with pull-out prevention helical grooves.
MM EC-CF-Z4-1.5xD
Interchangeable Solid Carbide Endmill Heads with 1.5xD Flute Lengths for Chatter Free Roughing and Finishing
• Do not apply lubricant to the threaded connection.
(1) Number of flutes
• Maximum depth of cut (APMX) while milling full slot from solid material is 1×DC
• Maximum width of cut for milling shoulder with APMX=1.5×DC is 0.3×DC
• Reinforced Weldon or SURELOCK shanks (with Safe-Lock® by Haimer pull-out prevention helical grooves) is strongly recommended
• In cases of unfavorable machining conditions, the cutting data should be decreased by 20-30%
MM EC-CF-Z7/9-1.5xD
Interchangeable 7, 9 Flute Solid Carbide Endmill
Heads 36° Helix with 1.5xD Flute Lengths
(2) Maximum ramping angle
• Intended for high-speed trochoidal milling and finishing operations with max. width of cut =0.1×DC
MM ERS-1.5xD
Interchangeable Solid Carbide Rough Milling Heads with 1.5xD Flute Lengths for High Metal Removal Rates
  • chatter
    chatter
  • depth of cut
    depth of cut
  • endmill
    endmill
  • flutes
    flutes
  • gang cutting ( milling)
  • milling
  • pitch
    pitch
  • width of cut
    width of cut
    Width of the milled surface, reflecting a face milling cutter’s radial engagement, and a peripheral milling cutter’s axial engagement, in the cut.
Additional Products from Iscar USA
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The double-sided CXMG inserts operate similarly to CCMT positive inserts and can therefore replace standard CCMT inserts. In some applications, they can also replace standard negative CNMG inserts.
Double-sided with a positive flank. Low cutting forces. Designed with a chipformer for general…
