Neodo S890
January 25, 2024
Neodo Increase Profitability in Rough, Semi-Finish, Square Shoulder and Face Milling Operations
ISCAR introduces new indexable milling cutters for 90° square shoulder and face milling applications which mount square inserts with 8 cutting edges.
This new family of tools was designed for rough and semi-finishing operations, intended for highly efficient face milling applications, primarily for steel and cast-iron.
The HELIDO S890 tool line offers a versatile and cost-effective tool for productive milling for varying cutting conditions.
The new HELIDO S890 FSZ …R08 face mills feature a 90° cutting edge angle and mount square double-sided inserts (S890 SZMU 08) with 8 cutting edges. The new cutters have a face mill design configuration and are available in a diameter range of 40-125 mm.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work holding fixture constraints.
S890 SZMU 08… insert features:
  • Square double-sided pressed-to-size inserts
  • 8 helical right-hand cutting edges for machining at depths of cut (D.O.C.) up to 5 mm
  • Specially shaped rake face insert which ensures a positive rake and low cutting forces
  • Strong and durable insert structure
  • Wide wiper flat for improving surface finish
  • An effective and economical solution for face and square shoulder milling
The inserts are produced from superior SUMO-TEC carbide grades, which provide excellent performance and longer tool life.
S890 FSZ…R08 milling cutter features:
  • 90° cutting edge angle
  • Maximum 5 mm depth of cut (D.O.C.)
  • Extremely rigid screw clamped inserts due to the dovetail profile of the insert pocket
  • Advanced cutting geometry which reduces cutting forces and assures smooth cutting and low power consumption
  • Coarse and fine pitch configurations of the cutters
  • Higher tooth density for improved productivity
  • Coolant holes (up to 125 mm Dia. cutters), directed to each cutting edge for efficient cooling and chip evacuation
  • A highly economical solution which provides an optimal price per cutting edge
  • Excellent performance for diverse machining conditions and interrupted cuts
Machined materials
  • ISO P (steel, ferritic and martensitic stainless steel)
  • ISO K (cast iron) application groups
Advantages
  • Productivity: High metal removal rates
  • Economical: Inserts with 8 helical cutting edges
  • Reliable: High process machining stability
The new family offers technical advantages combined with a very attractive price per cutting edge. HELIDO S890 FSZ …R08 cutters provide highly productivity solutions for face milling.
Cutting data
  • The table below defines initial feed rates
  • For initial cutting speeds refer to ISCAR’s recommendations for carbide grades
  • For machining under unstable conditions, the table value of the initial feed should be reduced by 20-30%
NEODO
The right tool for high productivity and cost reduction in Square shoulder and face milling
S890 FSZ-R08
Face Mills Carrying Double-Sided Square Inserts with 8 Cutting Edge
S890 SZMU-0804PN
Square Double-Sided Inserts with 8 Cutting Edges
  • coolant
  • depth of cut
    depth of cut
  • feed
  • fixture
    fixture
  • flat ( screw flat)
    flat ( screw flat)
  • gang cutting ( milling)
  • milling
  • milling cutter
    milling cutter
  • milling machine ( mill)
  • pitch
    pitch
  • rake
    rake
  • wiper
    wiper
Additional Products from Iscar USA
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
Deep drills with a 3 cutting edged insert (other manufacturers only offer inserts with 1 or 2 cutting edges). Highly accurate peripherally ground insert, provides high hole diameter accuracy of IT10.
The chip splitter produces narrow chips for efficient chip evacuation, enabling high feed…
