T-SLOT
January 25, 2024
 Interchangeable Solid Carbide T-SLOT Milling Heads for Slotting
The cutters consist of interchangeable solid carbide T-SLOT milling heads and cylindrical shanks assembled by means of a unique spline connection.
The spline connection is used to transmit the torque in the best way, ensuring very durable assembly to withstand considerable cutting forces during slot milling and bending forces caused by long reach overhang.
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
Features
  • Wide range of 32 mm (1.25 ") ,40 mm (1.5 ") and 50 mm diameter solid carbide milling heads with 8 ,10 and 12 effective teeth and width range of 1 -12 mm (0.046 – 0.375 ")
  • The solid heads are clamped onto the shanks with a central screw
  • Steel and solid carbide shanks with different lengths
  • SD Cab - Adapter for connecting SD T-SLOT heads with MULTI-MASTER shanks
Diameter range:
  • SD D32 mm (1.25")
No. of Flutes: 8
Insert width: 1 – 8.5 mm (0.046 – 0.25 ")
Insert max depth: 10 mm (0.393") with SP11 and 8 mm (0.315") with SP15.
Diameter range:
  • SD D40 mm (1.5").
No. of Flutes: 10
Insert width: 1 – 10 mm (0.078– 0.375 ")
Insert max depth: 13 mm (0.51") with SP13 and 11 mm (0.43") with SP17.
Diameter range:
  • SD D50 mm
No. of Flutes: 12
Insert width: 4– 12 mm
Insert max depth: 15 mm with SP19.
Grades
  • IC908
  • depth of cut
    depth of cut
  • gang cutting ( milling)
  • milling
Additional Products from Iscar USA
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
Deep drills with a 3 cutting edged insert (other manufacturers only offer inserts with 1 or 2 cutting edges). Highly accurate peripherally ground insert, provides high hole diameter accuracy of IT10.
The chip splitter produces narrow chips for efficient chip evacuation, enabling high feed…
