Tang-Grip, Slim-Grip
January 25, 2024
Pentagonal Adapters with 5 Pockets for Tang-Grip and for Slim-Grip (GFT) Inserts
ISCAR is expanding its parting line by adding pentagonal adapters with 5 pockets for TAG 2 & 3mm widths and GFT (Slim Grip) 1.2-1.6mm
TANG5GRIG for TANG-GRIP (TAG) Inserts
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm.
A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
TANG5GRIG Features:
  • Economical adapters with 5 pockets for TANG-GRIP and SLIM-GRIP inserts
  • No setup time after pocket replacement
  • Unique product, door opener for parting applications
  • The back of the adapters is designed with “V” shape geometry (wedge effect) to ensure maximum clamping forces and tool stability
  • Several adapters can be clamped on one holder
  • The tools and adapters are designed for JET-CUT cooling up to 340 Bar
  • Saves raw material due to the narrow SLIM-GRIP insert widths - 1.2mm & 1.6 mm
THMPR/L D22-JHP
Holders with High Pressure Coolant Channels for Pentagonal SLIM-GRIP Adapters
ADMP D22
Parting and Grooving Adapters With 5 Pockets for SELF-GRIP Inserts
* Optional, should be ordered separately
GFT-J
Thin Parting, Grooving & Slitting Single-Ended Inserts for Soft Materials
GFT-C
THMPR/L D45-JHP
Holders with High Pressure Coolant Channels for Pentagonal TANG-GRIP Adapters
ADMP D45
Parting and Grooving Adapters With 5 Pockets for TANG-GRIP Tangentially Clamped Inserts
  • coolant
  • gang cutting ( milling)
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
Additional Products from Iscar USA
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
Deep drills with a 3 cutting edged insert (other manufacturers only offer inserts with 1 or 2 cutting edges). Highly accurate peripherally ground insert, provides high hole diameter accuracy of IT10.
The chip splitter produces narrow chips for efficient chip evacuation, enabling high feed…
