Soliddrill Extra Long
January 25, 2024
Extra Long Solid Carbide Drills 30xD, 40xD and 50xD
ISCAR Introduces new extra long solid carbide drills in 30xD, 40xD and 50xD drill lengths for general applications.
The range encompasses the following:
30xD Ø.125-.391”
40xD Ø.125-.313”
50xD Ø.172-.250”
Features
  • 135° Point Geometry – Split point geometry for superior drilling penetration and accuracy.
  • Double-Margin Design – For improved drilling stability and smooth surface finish.
  • Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished.
  • Coolant Holes – Cooling the cutting edges improves chip evacuation during the drilling operation.
  • Coating – A multi-layer coating allows drilling at high speed. Excellent for drilling operations in steel (up to 45 HRC).
Potential Industries for Extra Long Solid Carbide Drills:
  • Automotive
  • Oil and Gas
  • Heat Exchangers
  • Machine Tools
SCD-SXC30
Solid Carbide Drills with Internal Coolant Channels, Drilling Depth 30x
SCD-SXC40
Solid Carbide Drills with Internal Coolant Channels, Drilling Depth 40xD
SCD-SXC50
Solid Carbide Drills with Internal Coolant Channels, Drilling Depth 50xD
  • coolant
  • flutes
    flutes
Additional Products from Iscar USA
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand…
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The double-sided CXMG inserts operate similarly to CCMT positive inserts and can therefore replace standard CCMT inserts. In some applications, they can also replace standard negative CNMG inserts.
Double-sided with a positive flank. Low cutting forces. Designed with a chipformer for general…
