Neofeed Cutters
January 25, 2024
Neofeed Cutter Tool Family for Highly Efficient Rough Milling for Increased Productivity and Cost Savings
The new NEOFEED cutters are available in the diameter range 2.00”-4.00” in the following two shell-mill design configurations:
  • FFQ8 -12 with 12° cutting edge angle for extremely high feed per tooth (fast feed milling) at depths of cut up of to .059”.
  • MFQ8 -12 with 22° cutting edge angle for milling with “moderate” feed milling (less than high but much more than common) at depths of cut up of to .118”.
  • When milling near a wall using MFQ8 D...-12 cutter up-milling is recommended.
The new shell mills carry the same double-sided square inserts FFQ8 SZMU 120520… with 8 cutting edges.
When mounted in a NEOFEED tool, the insert enables a positive tool rake angle which assures smooth cutting and reduced cutting forces and power consumption. The insert pocket has a dovetail shape that provides rigid and reliable insert clamping and improves the a cutter’s capability to withstand heavy load. These features provide increased cutting data for better productivity and for improved tool life.
The new FFQ8/MFQ8 D…-12 shell mill cutters feature a fine-pitch option for 2.00 - 4.00” cutters. This feature extends the range of application options for roughing specifically in the Die & Mold, Aerospace and general engineering industries.
FFQ8 SZMU 120520… Insert Features
  • Double-sided square insert with 8 cutting edges.
  • High-strength body structure.
  • The specially designed .0787” radius insert corner with reinforced cutting edge increases insert strength when milling near a wall.
  • Available with two types of cutting geometries (T/HP) for optimal machining different materials.
  • FFQ8 SZMU 120520... inserts are produced from ISCAR’s latest carbide grades with post-coating treatment technologies that guarantee greater tool life and higher productivity.
  • The same insert fits the both types of the new cutters.
  • An attractive economical solution due to insert cost effectiveness per one cutting edge.
FFQ8 SZMU 120520T - for steel, ferritic and martensitic stainless steel, cast iron and hardened steel (ISO P, K and H groups of application).
FFQ8 SZMU 120520HP - for austenitic stainless steel and high temperature alloys (ISO M and S groups of application).
FFQ8/MFQ8 D…-12 Cutter Features
  • FFQ8/MFQ8 D…-12 A fine-pitch design for increased metal removal rates.
  • Coolant holes directed to each cutting edge, for efficient coolant and improved productivity.
  • Protective coating of a cutter’s body provides better chip flow and protection from corrosion and wear.
Cutting data
The recommended cutting data are shown in the tables in the last pages.
NEOFEED
An advantageous tool for productive and cost-efficient rough milling
FFQ8-12
Fast Feed Face Mills Carrying Double-Sided Inserts with 8 Cutting Edges
• Radius for programming .142"
• To generate a straight surface without cusps, the width of cut most not exceed DC
• For slot milling or machining with high tool overhang, the maximum depth of cut should be reduced by 30%
(1) Cutting diameter maximum
(2) Number of inserts
(3) Maximum ramping angle
(4) For interpolation
(5) For interpolation
(6) Master insert identification
MFQ8-12
Moderate Feed Face Mills Carrying Double-Sided Inserts with 8 Cutting Edges
• Radius for programming .197"
• For slot milling or machining with high tool overhang, the maximum depth of cut should be reduced by 30%.
(3) Master insert identification
FFQ8 SZMU
Square Double-Sided Inserts with 8 Cutting Edges for High Feed Milling
• For side plunging, the initial cutting feed is 0.1 mm/t
• T- for steel, ferritic and martensitic stainless steel, cast iron and hardened steel
• HP - for austenitic stainless steel and high temperature alloys.
Averaged cutting data for FFQ8 fast feed cutters
* ISCAR material group in accordance with VDI 3323 standard
** Quenched and tempered
For machining in unstable conditions, the recommended cutting data should be reduced by 20-30%.
  • alloys
    alloys
  • coolant
  • depth of cut
    depth of cut
  • feed
  • gang cutting ( milling)
  • interpolation
    interpolation
  • milling
  • milling machine ( mill)
  • rake
    rake
  • width of cut
    width of cut
    Width of the milled surface, reflecting a face milling cutter’s radial engagement, and a peripheral milling cutter’s axial engagement, in the cut.
Additional Products from Iscar USA
The spline connection designation is SP… where the no. indicates the connection size.
The general duty cutting geometry of the heads is suited for efficient slot milling on a wide spectrum of workpiece materials for maximum depth of cut.
A new family of tools and economical 5 pocket adapters for existing TANG-GRIP inserts in sizes of 2 and 3mm. These new adapters will allow parting applications of bar diameters up to Ø45mm. A new SLIM-GRIP 1.2-1.6mm inserts for a pentagonal adapter suitable for parting up to 22mm bar diameter.
The advanced design combines a strong insert structure, a durable cutter body, secure mounting, and advanced carbide grades. This innovative solution enables face and square shoulder milling, while providing an additional option for milling close to shoulders where there are workpiece or work…
The NEOTURN XNMG demonstrates excellent chip control and highly stable tool life in a wide range of applications. The NEOTURN system also enables machining complicated workpiece shapes close to the tail stock where space is limited. This can be performed without replacing the holder and decreases…
The milling heads have been designed for shoulder roughing, semi-finishing and finishing applications with ramping down capability. The milling heads are available in .312-1.00” diameter range.
135° Point Geometry – Split point geometry for superior drilling penetration and accuracy. Double-Margin Design – For improved drilling stability and smooth surface finish. Polished Flutes - Chip evacuation is improved during deep-hole drilling when the flutes are polished. Coolant Holes – Cooling…
ISCAR is introducing 17 mm diameter PENTA inserts, designed for machining small size parts with up to 4 mm maximum grooving depth capability. The inserts are available in a range of widths from 0.25 to 3.18 mm, with different edge configurations for parting, grooving, turning and threading.
The XNMU inserts are the original concept of double-sided inserts with 4 right-hand and 4 left-hand helical cutting edges for slot milling cutters. These inserts are made of SUMOTEC carbide grades, designed for milling alloy steel, ferritic and martensitic stainless steel, and cast-iron.
The drill bodies are available in 3xD and 5xD length to diameter ratios. The inserts are supplied in a specifically developed user-friendly key, enabling easy mounting with no setup time.
The double-sided CXMG inserts operate similarly to CCMT positive inserts and can therefore replace standard CCMT inserts. In some applications, they can also replace standard negative CNMG inserts.
Double-sided with a positive flank. Low cutting forces. Designed with a chipformer for general…
