Height of accuracy
Height of accuracy
A noncontact, standoff-height sensing system for waterjet machines.
July 1, 2014By Alan Richter
As abrasive waterjet cutting evolved and enabled the production of complex, 3D part geometries, it became critical to accurately and efficiently know and maintain the standoff height, or distance, between the exit of the waterjet nozzle and the workpiece. This need becomes more important as the waterjet cutting head tilts to dynamically correct part taper or cut 3D shapes, such as bevels, from a flat sheet, because the standoff distance changes. When this occurs, the waterjet machine must maintain a fixed standoff distance while the jet is tilting to compensate for taper.
Traditional height monitoring methods are mechanical and touch the workpiece to follow the contour and gain the needed information, but the monitoring process becomes more complicated and challenging when waterjetting more intricate geometries, according to Dr. Mohamed Hashish, senior vice president of technology at Flow International Corp. "Originally, we just wanted to follow the shape on the part contour," he said. "Then, it became important to tilt the jet while maintaining a focal point on the workpiece to produce accurate parts."
He added that a secondary concern of a tactile method is the height monitoring device can scratch the workpiece.
DynaBeam_with%20detail.tif
Courtesy of Flow International
The DynaBeam laser sensing system from Flow provides a method for setting the nozzle offset height without contacting the workpiece.
As a result, Flow determined waterjetting needed a noncontact method—a waterjet industry first, according to the company—and turned to laser height sensing because it is an established technology. Flow developed what it calls the DynaBeam laser sensing system.
To determine standoff height, which typically ranges from 0.050 " to 0.100 " (1.27mm to 2.54mm), the company uses a diode laser mounted on the cutting head's end effector, Hashish explained. The laser hits the workpiece and is reflected back at an angle to a sensor on the laser device, which then calculates the distance the beam travels based on the angle. "It's a very basic principle called 'laser triangulation,' " he said, noting it needs to be performed in a clean environment.
However, with water splashing, abrasive flying and vapor rising, a waterjet machine is not a welcoming place for obtaining accurate distance information from a laser beam. Therefore, Flow shields the laser beam in an air jet to prevent water and debris from interfering with its path.
The DynaBeam sensor has an accuracy of ±0.004 " (±0.1mm), which Hashish said is suitable for waterjetting.
The laser height sensing system maps the natural, or original, state of the workpiece material prior to machining to obtain its topography, which can change during machining because of warping and stress relieving. This reduces the need for manual adjustment throughout the cutting process and, thereby, increases productivity, Hashish noted. Operators can automatically set the standoff height before every waterjet pierce of the workpiece or premap the entire workpiece.
"You can map the part as many times as needed to maintain cutting accuracy," Hashish said. "Usually, it's only required once at the beginning or sometimes before piercing in different locations every time you make a shape."
The DynaBeam system is available as a standard feature on the company's waterjet machines. "The noncontact idea is to have less maintenance, no moving parts, use standard tooling technology and allow free access to do 3D cutting," Hashish said.
For more information about Flow International Corp., Kent, Wash., call (800) 446-FLOW or visit www.flow waterjet.com.
  • stress relieving
    Annealing designed to relieve internal stresses caused by machining, welding, casting, cold working, quenching or normalizing.
  • waterjet cutting
    Fine, high-pressure (up to 50,000 psi or greater), high-velocity jet of water directed by a small nozzle to cut material. Velocity of the stream can exceed twice the speed of sound…
