Fairport, NY: Steiner Technologies partners with German manufacturer, Hermann Bilz to fill the void left by the discontinuation of the main provider of manual back counterbore tools in North America
⇒ Steiner Technologies is stocking HSS manual back counterboring heads from 10mm-76mm
⇒ Offset entry back counterboring tools are also being stocked in solid carbide and indexable insert options in a wide variety of metric sizes
⇒ Modular piloted front counterboring tools available in standard metric sizes in HSS, brazed carbide, and indexable insert options
⇒ Stock items can be shipped same day as ordered up until 3 PM (EST)
⇒ The Hermann Bilz line is being offered in conjunction with the fully automatic Autofacer which is designed and built per specific application in our Fairport, NY facility
- counterbore
counterbore
Tool, guided by a pilot, that expands a hole to a certain depth.
- counterboring
counterboring
Enlarging one end of a drilled hole. The enlarged hole, which is concentric with the original hole, is flat on the bottom. Counterboring is used primarily to set bolt heads and nuts below the workpiece surface.
- high-speed steels ( HSS)
- indexable insert
indexable insert
