Professional machinists searching for technical assistance on the internet would do well to check out Machiningdoctor.com, a website launched in November 2020 by a mechanical engineer with more than 30 years in the industry.
Erez Speiser, who spent much of his machining career working at Iscar headquarters in northern Israel, said he developed the Machiningdoctor.com website out of boredom during the COVID-19 pandemic. As the website grew—it now has 27 machining related calculators and a reported 250,000 page views per month—Speiser decided to make his online endeavor a full-time job as of March 2023.
Indeed, the website contains a wealth of information that is well-organized and bound to be of interest to professional machinists.
The calculators offered range from simple conversion tools to a more complex speeds and feeds calculator that provides cutting condition recommendations based on dozens of parameters, according to Speiser. Here is a list of the calculators offered on the website:
- Advanced Speed and Feed Calculator
- Advanced Thread Calculator
- Basic Milling Calculator
- Chip Thinning Calculator
- Chip Load Calculator
- Cut Depth Optimizer
- Basic Turning Calculator
- Surface Finish Calculator
- Knurling Calculator
- Facing Calculator
- Metal Removal Rate Calculator
- Machining Power Calculator
- Hardness Converter
- Ra to Rz Converter
- Inch Decimal/Fraction Converter
- SFM to RPM Converter
- Imperial to Metric Converter
- Metric to Imperial Converter
- RPM to SFM Converter
- Carbide Grades Wizard
- Carbide Grades Converter
- Carbide Grades Comparison Tool
- Engineering Tolerances and Fits (ISO 286)
- Drilling Calculator
- True Position Calculator
- Tap Drill Size Calculator
- Sine Bar Calculator
Visit the Machiningdoctor.com website to learn more. While the website carries advertising, Speiser offers an ad-free version of the website to visitors willing to pay a subscription fee of $1.50 per month.
Dennis Spaeth, publisher and owner of Cutting Tool Engineering, will welcome Speiser as the inaugural guest of Bourbon with the Editor, a manufacturing podcast for CTE's 100,000-plus audience of metalcutting professionals. Podcast will take place at 11 a.m. CST Thursday, March 7. More information to come.
- feed
- hardness
hardness
- knurling
knurling
Chipless material-displacement process that is usually accomplished on a lathe by forcing a knurling die into the surface of a rotating workpiece to create a pattern. Knurling is often performed to create a decorative or gripping surface and repair undersized shafts.
- tap
tap
- turning
