1016 Bandsaws
1016 Bandsaws
Scotchman Industries has recently improved its 1016 Band Saw Series.
July 1, 2011
Scotchman Industries has recently improved its 1016 Band Saw Series. This series includes our FH1016 (fixed head) and SH1016 (swing head) band saws. Improvements include a new look with radius band blade doors for greater strength, forklift slots are now build-in, band door interlocks are standard and the coolant tank is new and improved with larger coolant capacity and chip removal.
The 1016 capacities are 10" x 16" at 90 degrees and 10" x 10-¾" at 45 degrees and they are powered by a 2HP infinite variable speed drive motor allowing the saw to run at speeds ranging from 105 to 275 fpm. The hydraulics feature a fine adjustment of the head feed control, quick approach and head hold for easy line up of marks. The optional pneumatic head raise and vise are available for a full-cycle machine. These machines are made in the U.S. and come with a 3-year warranty.
