Combining a variable speed drive in a rugged unitized welded steel frame and solid cast iron table ensure that Palmgren’s Vertical Toolroom Saws are well equipped for a variety of jobs.
The construction enables the saw to easily handle contour sawing, beveling, slicing, ripping, stack cutting and cutting off various materials from aluminum, brass to steel. The variable speed drive system allows for quick, easy speed changes so the operator can match the correct speed to the blade and cutting application. The design enhances productivity and versatility to any metalworking operation.
The extra-large cast iron titling table on the #6883119 Vertical Toolroom Saw from Palmgren can handle a wide variety of workpiece sizes and shapes.
- metalworking
metalworking
- sawing
sawing
- sawing machine ( saw)
