14-Inch Cold Saw
14-Inch Cold Saw
The saw features an advanced gear box design utilizing taper roller bearings, hardened and ground steel gears with a high-quality bronze worm gear in an oil bath. Secure clamping of the workpiece optimizes its accuracy. The saw delivers burr-free straight or angle cuts.
Ideal for cutting low and high carbon steels, medium gauge tubes and profiles, Palmgren's 14-inch Cold Saw consistently delivers precise smooth cuts. The saw features an advanced gear box design utilizing taper roller bearings, hardened and ground steel gears with a high-quality bronze worm gear in an oil bath. Secure clamping of the workpiece optimizes its accuracy. The saw delivers burr-free straight or angle cuts.
The #9683337 14-inch Cold Saw from Palmgren® consistently delivers precise, smooth burr free straight or angle cuts. The saw comes mounted on a heavy-duty solid steel floor stand.
