18-inch Vertical Wood/Metal Band Saw
The specially designed multipurpose saw effectively works on a variety of materials that includes wood, plastic, composites and ferrous and non-ferrous metals. It comes with two blades -- a ¾-inch-14 TPT metal blade and a ¾-inch-TPS wood blade.
18-inch Vertical Wood/Metal Band Saw from Palmgren®
The versatile 18-inch Vertical Wood/Metal Band Saw is really two saws in one. The specially designed multipurpose saw effectively works on a variety of materials that includes wood, plastic, composites and ferrous and non-ferrous metals. It comes with two blades -- a ¾-inch-14 TPT metal blade and a ¾-inch-TPS wood blade. The vertical saw features a unitized welded steel frame, cast blade wheels and a large ground cast iron worktable that tilts up to 45 degrees. A 15-inch model is also available.
