2613-D36 Vertical Bandsaw
The DoALL 2613-D36 vertical band saw is designed to cut brittle, dusty material where the dust is highly abrasive and may be flammable.
The DoALL 2613-D36 vertical band saw is designed to cut brittle, dusty material where the dust is highly abrasive and may be flammable. The 2613-D36, with a diamond saw blade, features variable speed control which maximize material output and yield.
A unique back gauge design allows for extremely accurate cutting, holding cuts up to thousandths of an inch. The design also features multiple dust/swarf control mechanisms to avoid contaminating critical areas.
