6 x 12 Bench Surface Grinder
Suitable for small shops, Palmgren's 6 x 12 bench surface grinder is an economical option because it has many of the same features found on larger units. The grinder's Meehanite cast iron construction reduces vibrations while maintaining rigidity and accuracy.
January 5, 2018
Its precision steel balls produce an extremely smooth table operation along the ways. It features a swarf guard, easy-to-read dials and an optional heavy-duty steel floor stand.
When close tolerances are needed, the grinder delivers mirror-like finishes to metalworking projects. Its cast iron construction minimizes vibrations and its precision steel balls produce an extremely smooth table operation.
