Stock Drive Products, an ISO 9001 registered manufacturer, offers a wide selection of bearings in many different styles to fit your application. Of particular interest are the series of ABEC 3 ball bearings. These bearings are suitable for commercial applications that require low friction movement. They support both axial and radial loads with minimal play.
Both inch and metric size bearings are available. They come in plain and flanged styles and can be single or double shielded, if shielding is required. Standard options for lubrication include oil and both military and commercial grade grease, but other lubricants are available on special order to ensure your application needs are met. Static and dynamic load ratings go up to 1030 lbf and 1620 lbf, respectively.
