PFERD has introduced its CC-GRIND-FLEX, the next generation of semiflexible grinding discs. This high-performance disc blends weld seams on large surfaces without leaving dents or bumps typical of a rough grinding wheel or fiber disc. When using the CC-GRIND-FLEX, an absolutely flat surface can be achieved.
This complete smoothing of butt welds – without dents or bumps – is made possible by an innovative design that integrates a layered fiberglass backer with a high-performance coated abrasive. The geometry of the cooling slits ensures high air flow. This reduces the thermal load on the grinding discs and workpiece.
The CC-GRIND-FLEX, a semiflexible version of the CC-GRIND-SOLID is available in 4-1/2 in. and 5 in. dia. with 7/8 in. bore. Coarse grit with its highly aggressive abrasive for increased stock removal or a fine grit to produce a superior finish are available. The new disc provides up to 50 percent less noise and vibration during use when compared to a conventional grinding disc, with less risk of gouging and is for weld blending on both flat and curved surfaces.
For use on steel, the new CC-GRIND-FLEX is suited for automotive and trailer manufacturing to blend butt welds in fenders; as well as in power generation for water chute production. Other applications include; general metal fabrication (machine guards, security gates, etc.); maintenance and repair operations; as well as other butt-weld grinding applications.
- abrasive
abrasive
- coated abrasive
coated abrasive
Flexible-backed abrasive. Grit is attached to paper, fiber, cloth or film. Types include sheets, belts, flap wheels and discs.
- flat ( screw flat)
flat ( screw flat)
- grinding
- grinding wheel
grinding wheel
