»contour-profiled« Profile Grinding Wheel
Lach Diamond Inc. offers a grinding wheel with a metal bond for deep grinding – hitherto almost unthinkable. For the first time, newly developed bond variations are available for profiling during the deep grinding of carbide, high-alloyed steel, ceramics and, in a special specification, even unhardened steel.
What was only possible in time-intensive conventional grinding procedures or with several diamond and CBN grinding wheels, is now accomplished with only one profile grinding wheel known as »contour-profiled«, or “one for everything.“
The innovative metal bond allows contour grinding from the solid – and with profile depths of up to 15 mm, e. g. bottom blades or profile blades – there is absolutely no impact on tool life, even at full feed rate.
The result: Repeatable precision profile cuts in mass production. The advantage is obvious: Significant reductions to a fraction of the original total cost.
  • ceramics
    ceramics
  • cubic boron nitride ( CBN)
  • feed
  • grinding
  • grinding wheel
    grinding wheel
  • profiling
    profiling
