Customized TCH-550 Model 550°F Truck Oven
This Grieve truck oven has 6" insulated walls, an aluminized steel interior and aluminized steel exterior with enael finish. Features include a purge timer, two-position dampers on fresh air inlet and exhaust outlet and a 1200 lb. capacity stainless steel loading truck. Additional features include a 325 CFM powered forced exhauster with an airflow safety switch. The oven includes all safety equipment required by NFPA Standard 86, IRI, FM and OSHA.
August 22, 2020
This Grieve oven is a 550°F (288°C) new truck oven customized from the standard TCH-550 model and is currently used for heat processing parts at the customer's facility. Workspace dimensions of this oven measure 60" W x 60" D x 60" H. 30 KW are installed in Incoloy sheathed tubular heating elements, while a 2000 CFM, 2 HP recirculating blower provides horizontal airflow to the workload.
Controls on this Grieve oven include a UL listed control panel, a programmable temperature controller, SCR power controller, a circular chart recorder and a circuit breaker disconnect switch mounted through control panel door.
